New Main Panel Placement
Old 05-13-10, 05:18 PM
I am doing a full remodel, and upgrading the elec service to 200 Amp. I am changing the location of the panel, and want to install it in an inside wall, between the studs, surrounded by the drywall, about 8-9 feet from the meter. I will have the 30x36 clearance and meet the height requirements, but I have been unable to find anything on installing the main panel between the studs of an inside wall. Can I install this within the wall, or must it be on the outside the drywall? Am I missing anything else? I will have an electrician do all the wiring from the panel to the outside service.
Thanks, Tom
Old 05-13-10, 05:36 PM
CasualJoe's Avatar
Received 164 Votes on 147 Posts
Thanks, Tom
Sure, you can install it on an inside wall, but you'll also now have to install a disconnect, either fusible or with a circuit breaker.
Old 05-13-10, 06:51 PM
E
also the new panel becomes a sub panel. and must be wired accordingly. ground rods and water ground to the disco outside, grounds and neutrals seperated at sub panel. 4 wire feeder from disco to sub panel
also a 200 amp panel may or may not fit in a standard stud spacing.
Old 05-13-10, 07:07 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
There should be no issue fitting a 200 amp panel in standard 16" OC stud bays. The panels are 14 1/2" wide.
Old 05-13-10, 07:19 PM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
As pointed out the main service wires must be terminated to the main disconnect "at the closest point of entry". This is, in almost all cases, less than 5' inside the home. You can do what you describe but you will have to install a disconnect on the outside of your home. This is done quite often and in many cases is not a big deal, it is just an added expense.
Old 05-14-10, 05:38 AM
E
i couldnt remember if the 200's were wider. thanks for the clarification
Old 05-14-10, 05:51 AM
pcboss's Avatar
NP, sharing knowledge, without attitude, is one of the traits of this board. Thanks for contributing.
