Wiring 220v Oven with 10-2 not 10-3
Old 05-18-10, 06:23 PM
P
I used 10-2 to wire a 240v oven. I realize I should have used 10-3 wire, but I ran the wire all the way from the panel to the outlet before I realized my mistake. I used the bare ground as my neutral. When finished, I taped the bare ground so there were no bare surfaces exposed. Should I rip out the 10-2 and replace with 10-3?
Old 05-18-10, 06:37 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes. You need to replace it with 10-3 or 8-3 depending on the oven requirements. What you did was wrong and unsafe. Turn off the breaker till you can fix it.
Old 05-18-10, 06:58 PM
pcboss's Avatar
Received 83 Votes on 71 Posts
What are the ampacity requirements for the oven?
I agree with Ray, what you installed is unsafe and needs to be replaced.
Old 05-18-10, 07:54 PM
F
No!! Don't do it !!!!
That is competly illegal to do this.
I am sorry but you have to pull this cable out and redo it correct and the bare grouding conductor is not used for current carry conductor at all.
You have to put in correct cable you will need 6.0mmX3 with ground { 10-3 AWG with ground }
Merci,Marc
Old 05-19-10, 05:40 AM
You will need to remove it and install 10-3.
Besides being the ground wire, it does not have the gauge thickness to carry the loads of the main conductors.
Spenceq
Old 05-19-10, 09:02 AM
I
Received 43 Votes on 41 Posts
What are the electrical requirements of the oven stamped on the nameplate or in the installation manual? Built-in ovens do not always require 10-3.
Old 05-20-10, 08:42 PM
SilverTattoo's Avatar
Run the 10/3..(if its 30amp!) What were you thinking? Call in a pro! 30amps is prob a guess also. It is prob 30 but did you even look to see? This is a BIG FIRE HAZARD!!
Never use a wire with NO INSULATION to carry current!!!
Flip that breaker to off, take the wire out of the breaker, walk away and call a pro.
