Xantrex Trace C40 charge controller schematic
Received 0 Votes
I am looking for a Xantrex Trace C40 charge controller schematic. I run an off-grid setup that drives a pool pump and mine quite charging. I can set the bulk and float voltages via the pots so it's somewhere in the circuit. I can also see the battery voltage via the metering panel but not the incoming solar PV supply voltage.
Thank You in advance, JohnF
