using mounting screw for grounding
Old 05-27-10, 08:42 PM
D
at couple locations, the original installer looped the ground wire around the mounting screw of the switch in stead of using the "ground screw." i have found this for both plastic as well metal boxes.
while the contact seems to be good so the grounding is being achieved, i thought this a code violation. is it?
Old 05-27-10, 08:51 PM
F
Received 35 Votes on 27 Posts
Yes, this is a code violation. The mounting screws are NOT for equipment grounding.
Old 05-27-10, 10:13 PM
I
Received 43 Votes on 41 Posts
It is a code violation now, however historically this was a common practice.
Old 05-28-10, 03:22 PM
D
thanks ibpooks and furd
i guess 23 yrs back it was OK...
Old 05-28-10, 04:06 PM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
Just because it was a common practice didn't make it right even back then. I have also seen in years past a common practice of using the romex clamp screw in metal boxes for grounding, but that wasn't right either.
