#12awg on a 15 amp circuit
Old 06-07-10, 05:55 PM
C
i'm adding some recessed lights in a hallway and my house is currently wired completely with #12awg (on 15 and 20 amp circuits). is it safe to use #14awg on the new recessed lights. (they'll be on a 15amp)
Old 06-07-10, 06:02 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
No Pro...but all wiring on a circuit has to be able to support the max rating. So 12ga at the end of a 15A run wired with 14ga is OK (I think..but its bad practice), but you can't put 14ga at the end of a 12ga run....
Doesn't matter what the breaker says..it's the wire that matters.
Wait for the experts...but I think thats pretty accurate....
Old 06-07-10, 06:30 PM
R
To answer your question your can as long as that #14 wire is on a 15 amp circuit breaker. Also, please make a note of this on your wire at the circuit breaker just in case someone comes in your home thinking that he could put a 20 amp breaker on this circuit because it has #12awg wire on the breaker not knowing you have #14 in this circuit. BUT I beleive the correct way to do this is to finish them up with #12 wire. This will also give you more room to add to this circuit if you wanted to put a 20 amp breaker on the circuit. Good luck!
Jim
Last edited by stickshift; 06-08-10 at 11:14 AM. Reason: removed unnecessary quoting of entire post
Old 06-07-10, 08:17 PM
I
Received 42 Votes on 40 Posts
If your house is wired entirely with #12 wire, then there's a good chance you have a local code that requires it. I would stick with the #12.
Old 06-08-10, 10:34 AM
C
the town uses the 2002 National Electric Code
anybody know if this scenario complies?
Old 06-08-10, 10:42 AM
Tolyn Ironhand's Avatar
Received 175 Votes on 157 Posts
2002 code does not require #12 for an entire house. Your local codes might require it in addition of wiring methods such as metal conduit. A call to your local inspector would clear this up much faster then us guessing where you live and why you have circuits that are under fused. (15 amp on #12 wire)
Old 06-08-10, 10:54 AM
I
Your installation exceeds 2002 NEC which would allow the smaller #14 wire on 15A circuits. The fact that someone used the more expensive #12 makes me think that it may be required by a local code above and beyond NEC. It could just be that your electrician had a bunch of #12 on his truck.
Old 06-08-10, 11:07 AM
C
they may have been the case in 1975 when the house was built. Brand new homes in the area use 15amp for lights with 14awg so I know it's not a code on top of the NEC. must have been a 1975 thing.
Old 06-08-10, 04:04 PM
D
mixing 12awg and 14 awg is disgusting. Use 12 gauge
Old 06-08-10, 06:21 PM
CasualJoe's Avatar
Received 74 Votes on 65 Posts
I don't suppose there is a possibility the 12 AWG conductors could be aluminum? If so, 12 AWG aluminum must be protected at 15 amps. I believe aluminum wiring was still being used some in the mid 70s.
Old 06-08-10, 06:24 PM
Mixing #14 and #12 on the same circuit is disgusting. Using #14 on a 15 amp circuit is just fine.
Old 06-09-10, 03:57 AM
D
Mixing 12 and 14 for the sheer fact that you already have the wire, or dont want to spring the extra $10 or so for #12 is ridiculous.
OP, why wont you stick with #12
Old 06-09-10, 06:20 AM
Newer, larger house? In such cases 12AWG is sometimes installed on 15A circuits to reduce voltage drop (usually on outlet, not wiring, circuits though).
Old 06-09-10, 10:35 AM
C
it's not aluminum, it's copper.. thanks for the replies. i'll use #12.
my reasons were because i had the #14 and it's easier to work with most of the time.
