Basement wiring question
Received 0 Votes
Hello folks. Didn't the Governor of Ohio pass an electrical code requiring ACFI's a few years back? What rooms are those required for? My brother is finishing a basement, wants my help, but I want to make sure that it is done according to Ohio code. I also assume that the outlets are just left at normal height since it's just another livable space in the house. Thanks,I've never messed with basements before and am not sure if things are different down there. Thanks.
Received 0 Votes
As I look at the breakers in the box, only the bedrooms and bonus room have that AFCI protection, the rest of the house just has the normal 15/20 amp circuits. The house was built in 2008, so I'm not sure what the basement would qualify for. Any Ohio people have any insight into this?
Ohio had a temporary exemption of AFCI and other 2008 code requirements which I believe expired some time in 2009. It is likely your house was permitted either before the 2008 code came out or during the exemption period. Any new work should comply with NEC 2008 or local code if you have one.
It is strange that your home's bedrooms would not be AFCI though -- that requirement has been in since 2002 code. Perhaps your city or county has a local code which overrides the state?
If you are on 2008 code all living spaces (finished rooms) require AFCI breakers; prior versions only require AFCI breakers for circuits which serve receptacles, lighting and smokes in bedrooms. Any rooms in the basement that remain unfinished must have GFCI receptacles.
The receptacle height can be of your choosing -- 12" - 16" is typical for living areas. Any new receptacles you install should be TR (tamper-resistant).
