breaker
Old 08-16-10, 03:30 PM
Thumbs up breaker
I would like to know if its ok to use a 20 amp gfi with 12/2 wire on a 15 amp breaker. thanks joe4h
Old 08-16-10, 04:16 PM
pcboss's Avatar
Received 78 Votes on 66 Posts
A GFI with the 20 amp T-slots cannot be used on a 15 amp circuit. It can be used on a 20 amp circuit. Since the wire is the correct size for 20 amps switching the breaker would be the thing to do. You could also install a 15 amp GFI. There are few things that actually require the 20 amp T-slot.
Old 08-16-10, 06:47 PM
F
Received 34 Votes on 26 Posts
If this is an existing circuit that has #12 wire connected to a 15 ampere circuit breaker be VERY cautious about swapping for a 20 ampere circuit breaker. There may be parts of the circuit wired with #14 wire and that could be the reason for the "apparently" undersized circuit breaker.
Old 08-18-10, 06:49 PM
breaker
could someone please tell why it's not ok. thanks
Old 08-18-10, 07:01 PM
pcboss's Avatar
According to National Electrical Code Table 210.21(B)(3) the receptacle rating for a 15 amp circuit must be not over 15 amps. A 20 amp circuit can have a receptacle rated 15 or 20.
Old 08-18-10, 09:28 PM
F
It can be allowed but the issue is the T sloted recetaple that what seal the deal { AKA not allowed } if standard 15 amp duplex GFCI receptale then it is not a issue due they are rated for 20 amp feed thru.
Merci.
Marc
