Odd generator plugin
There is a plugin site in the metal box where my main power meter is. I was told by the home inspector that this is where I can hook up a backup generator when power is out. There is also a switch I am supposed to turn off to prevent the power from escaping to the grid. I have not been able to find a generator cord that would actually fit in this plugin. Is this perhaps of some old standard? Where could I find a generator cable like this. My generator has just a basic 120/240 4-prong outlet, which seems to be pretty much standard for newer generators.
The picture of the plugin should be behind this link:
Picture 004 | Flickr - Photo Sharing!
I looked around in a couple of big box stores just to see if they even sell a separate 3-prong plug that would match this one, but could not find one. All 3-prong plugs had the "bent" prong bent inwards, not outwards like this one. The switch is not wired into the main panel at all. It is in my main meter box in a pole 100 feet from my house. I was told that if I use a generator I just need to go around my panels and manually switch off all but just a couple of essential circuits I can run with the generator.
Rules will vary by different power companies and COOPs, but I have never heard of one sealing the customer's panel. I'd question the legality of it unless it contains unmetered connections or metering equipment such as CTs. How big is the service? 200 amp, 400 amp or bigger?
The closest one would be the L6-15R. Would it make sense that it is only 15A/250V?
Not a CS6364? I thought I was just missing something in the cobwebs in the pic. It's pretty clearly marked 50 in the center.
No electrician of course....but aren't boat and RV plugs also subject to codes?
So, if this is the case, can i find a generator cord with this kind of female end somewhere, or do I need to build one myself?
I'll let the electricians answer for sure...but you'll probably have to build one or replace the inlet. Since you have a 4 wire out...I don't know how you'd connect to a 3 wire in.
And as was said..you'd need to verify the wiring as it may be for 120 not 240.
This one actually has ground too, in addition to the X, Y and Z prongs. You can see the ground plate in the pic as well as in the NEMA Chart you provided. So this is actually a 4-wire setup.
Looks like I found an answer for this one. I can buy a 50 amp generator cord and 30 amp to 50 amp generator adapter from a RV supply store.
Ahh duh...I missed the ground in the pic...as well as the chart...
Like I said...no Electrician.
Look at footnote #3, it's a non-NEMA twistlock. You might be able to order it, but you'll have to locate it in a catalog at a supply house most likely. I think I'd change it to a 20 or 30 amp inlet to match the output of your generator.
Before you do anything, refer back to ray2047's post and tell us about your transfer switch and how it's wired to this inlet.
I finally figured out how to open the lower part of my meter box where the receptacle and the switch are, without breaking the COOP seal. Here are the pictures:
The receptacle side:
Picture 006 | Flickr - Photo Sharing!
The switch side:
Picture 007 | Flickr - Photo Sharing!
The guts:
Picture 008 | Flickr - Photo Sharing!
#21
I have see that all the time in Farm area so it is common but the way it set the transfer switch it will be at lower location as OP show the photo and I think that is a class 320 meter socket { aka 400 amp service } but some case it will be just a plain jane 200 amp service as well.
Most farm transfer switch I have ran into normally are pole toppers.
So I am pretty sure that is a legit 50 amp twist lock CS type { Californine Specail }
However there is one warning in that area it is unfused area and only way you can kill the power in that area is turn the transfer switch to off setting { the handle will be in Horzontal postion }
The handle in down postion will be on generator mode but you have to make a judgement call to see how much load you can use without tripping the generator breaker.
But the 50 amp twist lock receptale is good up to about 12 KW unit or so any larger generator you will have to change the recetale to larger one.
Merci.
Marc
Merci.
Marc
#22
The electric co-ops probably started putting them in to discourage farmers from using suicide cords on their PTO generators.
#23
This is a "farm style" transfer switch.. just about every farm has them if they have a generator...the panel usually is wired with a 3 wire 4awg octopus cord that plugs into the PTO generator..yours is wired with a 50 amp twistlock
your pretty much always going to run into having a bonded neutral at your generator when dealing with the 4 prong receptacle and obviously the neutral is also bonded in the service switch so you either need to install a 4 prong inlet running both to the bonding bar ..or bond the ground and neutral in the cord IF the generator neutral is NOT bonded
If you have access to a tractor used pto gennys are very affordable and you already have the most expensive part..the 200 amp transfer switch
#24
The inlet is already mounted to the side the enclosure. From the pictures of the switch it appears that the grounded conductor is not switched. If that is the case, then the neutral sould not be grounded in the generator or cord.
#25
Received 38 Upvotes
This is correct. The "neutral" (grounded conductor) needs to be bonded to the equipment ground in one place only to avoid parallel currents on the neutral and equipment ground conductors. The generator should NOT have a neutral-to-equipment ground bond at the generator or the inlet connector, only at the neutral/equipment ground buss in the transfer switch.
