Reload this Page >
3 capacitor 240v motor, how to hook up capacitors? On SpeedAire 5F563 compressor
Old 10-12-10, 10:21 PM
Originally Posted by familyCJ7 View Post
Ok I took a better picture of the wires.
We hooked up #1 as the Common
We hooked up #2 as the Run
We hooked up #3 as the Start
This blew one of the capacitors. If we meter #2 and #3 against #1 and get 2.6ohms. If we meter #2 and #3 we get 0.4ohms.
Which wires would be the Common, Run, and Start?
I did do the ohm meter tests. Did I do them right?
Old 10-27-10, 01:58 AM
Guess nothings came up yet. Might just have to take it somewhere
  #43
Old 10-27-10, 04:19 PM
braether3's Avatar
really isnt that simple when you done know what leads are what...the labels are usually universal and most are wired in a similar fashion but we need to know the labels
  #44
Old 10-29-10, 01:44 AM
Yea I know unfortunately the wire from the motor to the capacitors are unreadable. I think I'm just going to take it to an electrician who rebuilds motors and see how much they will charge to hook up the start and run capacitors. I don't think it should cost much since that's the only thing that needs to be done.
  #45
Old 11-10-10, 11:06 PM
Still not running! I really don't want to haul it to someone to fix. I'm going to get the Ohm Meter out and meter it every possible way it can be and post what I get.
  #46
Old 11-13-10, 09:04 PM
I labeled the wires coming from the motor 1,2 and 3. I metered from 1-2 and got 2.5ohms, 1-3 and got 2.6ohms, and 2-3 and got 0.4ohms.
So #1 is my Run
#2 is my Constant
#3 is my Start
Correct?
  #47
Old 11-14-10, 07:35 PM
So #1 is my Run
#2 is my Constant
#3 is my Start
Correct?
Anyone? Would like to get it running asap!
  #48
Old 11-14-10, 07:58 PM
I just got the motour drawing not too long ago however there were a issue the diagram and numbers did not match up to your motour at all.
I did resend the details and they will call me later this afternoon { I am still in Paris France }
Merci.
Marc
