Indoor wiring question
Old 09-08-10, 12:18 PM
I have a small playhouse that I'm running some electric to. In order:
1. Power source
2. Standard power outlet
3. Switch
4. Light 1
5. Light 2
I would like for the power outlet to remain powered even if the switch is turned off. Light 1 and 2 should only be on if the switch is on.
Can I just wire these in a straight sequence and it will work as expected? If I must then I can reverse 2 and 3 to make the switch control all three.
Thanks!
Old 09-08-10, 12:22 PM
I
Received 44 Votes on 42 Posts
Yes they can be wired in that order using 12/2 or 14/2 cable; the hot is broken by the switch. If this is outdoors, NM-B romex cannot be used. GFCI protection is required, perhaps bubble covers also. The location of the GFCI affects required burial depth. Since you said playhouse I would also strongly recommend TR (tamper-resistant) receptacles.
Old 09-08-10, 04:35 PM
chandler's Avatar
Received 6 Votes on 6 Posts
"Playhouse" as in theater, or as in kids-going-crazy?? If the latter, I would suggest a GFCI breaker to control all the wiring from the box to the house, just in case.
