remotely controlled
Old 09-21-10, 11:59 AM
Bernard_01's Avatar
remotely controlled
greetings all,
is there such an item as a "romote controlled single pole switch" ? I want to control my security light without haveing to get up to go to the switch. THANKS.
Old 09-21-10, 12:08 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Sure...depending on the wattage...there are plenty of wireless switches you could use. I had that for some floodlights..and I just took the wireless transmitter (designed for surface mount on a wall) and used it as a remote that I could move around.
Lutron brand IIRC...
Old 09-21-10, 12:09 PM
I
Received 45 Upvotes on 43 Posts
Yes, there are a number of manufacturers of "home automation" switches that have remote control. Leviton, Smarthome, X-10, Maestro, etc all have switches with remote capability.
Old 09-24-10, 08:07 AM
Bernard_01's Avatar
bit more clear on my question
greetings all, my security lights are existing hard wired floods all installed. they are controlled by a single pole switch also hard wired. Is it true that the only modification I need to make is to the SP switch itself? I assume I will purchase a type of receiver that takes the place of the SP switch? Then that receiver will be controlled by a transmitter (remote) ? thank you all. -Bob
Old 09-24-10, 09:57 AM
I
Yes that's correct. I believe they also make them that screw inline with the bulb or mount inside the light junction box.
Old 09-26-10, 07:01 PM
Z
Received 416 Upvotes on 369 Posts
Something like this might work...
Heath/Zenith BL-6133-WH Wireless Add On Switch, White - Smarthome
There are other options out there too. Just be careful, this one supports up to 500w, and others may be even less than that.
