Grounding rod for subpanel.
Old 09-27-10, 07:27 PM
Hello, thanks for you help in advance. I've seen different threads saying that if you have a subpanel in a separate building, then you should have a grounding rod for that subpanel. Other responses have said that emphatically, do NOT have a grounding rod for a subpanel in a distant building. Is it optional or should you always rely on the main panel ground? Thanks.
Old 09-27-10, 07:31 PM
HotxxxxxxxOKC's Avatar
Ground rod required per 2008 NEC 250.32. Ground rod is seperate from the one going from main panel to sub.
Old 09-27-10, 08:05 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
Here are some pictures to help: http://forum.doityourself.com/electr...-drawings.html
Old 09-28-10, 09:26 AM
Received 42 Votes on 40 Posts
A subpanel in an outbuilding always requires a grounding electrode system, which is usually one or two ground rods with brass acorn clamps attached to the subpanel ground bus with #6 copper wire.
A single circuit (no panel) to an outbuilding does not require a GES.
Old 09-28-10, 07:13 PM
Thanks, the pictures help to clear it up
