Evcon wall mounted thermostat my husband needs help with the wiring
This is an older model Evcon wall mounted that got pulled off the wall, he doesn't know where the four (4) wires go to that are hanging out of the wall. The faceplate is off, they are color coded: red, white, green and blue. Can anyone please help, it's very hot in here, we live in a mobile home in Newburgh, Indiana. Please, Please will somebody help us, it's so hot! thxs
If you have central air, along with the furnace, it must be red wire to red stat terminal(for incoming power), white wire to white stat terminal (for heat), green wire to green stat terminal(for fan ON), blue wire to yellow stat terminal(for a/c).
