Need Replacement Circuit Label for inside Panel Door
Old 10-23-10, 09:15 AM
Greetings!
Can anyone point me to a link where I can get a new circuit label to stick on inside of my service panel doors?
I have Square D HOMC42UC and a HOMC24UC
As written by the installer the legibility is poor and with unclear descriptions etc.
Thanks for any help. FF
Old 10-23-10, 09:53 AM
Received 6 Votes on 6 Posts
Panel Directory
I use a spreadsheet to make panel directories and tape them to the inside of the panel door.
Old 10-23-10, 05:14 PM
That is exactly what I did but I used Microsoft Word Processor fiz:
1. Hall light 2. Microwave
3. Pool Pump 4. Bedroom 1
5. and so on and so on.............
I then cut it out and put in in a plastic sleeve and taped it to the inside of the door with clear tape.
Worked fine.
Old 10-23-10, 10:21 PM
Most common way I do is make a print sheet and fold it up and put in a plastic pocket inside the door and slip printsheet in there due the print sheet will be much larger than the door itself so you can able read it more clear than it was written on the door itself.
Oh yeah just don't put a person name in the bedroom or other area just say North bedroom or East Bedroom etc etc it will simplify the way it can look for it. { I have done this the same way with commercal buildings as well }
Merci,
Marc
