Another sub-panel in the garage thread.
Old 10-24-10, 10:43 PM
I am Installing a sub-panel in my garage a 100 amp square d homeline. I am running it on a 50 amp breaker from my 125 amp main. I will only be using half the available breaker slots. I was given about 850 feet of (new) 6 awg wire and a roll of 8 awg for the ground. My distance is between 60 to 75 feet max through my attic .
1. I am using 3/4 conduit also free! How many wires can fit of this size? (three #6 and one #8?)
2. since I have so much wire can I double the number of wires? (four #6 and two #8) or will that not fit or is ill advised? meaning using two wires as one to increase capacity to maybe utilize a 70 amp breaker?
3. what will #6 wire carry 50 amp, 60 amp?
I assume that the doubling of wires is not permitted but I am not sure. Any help is greatly appreciated.
Old 10-24-10, 10:52 PM
Assuming the insulation on the wire is type THHN, THWN or THWN-2 you could have up to four #6 wires in a 3/4 inch conduit so three #6 plus one #8 is okay. Be sure there are no more than 360 degrees of bends in the conduit between access points, either a conduit fitting Tee, or Ell fitting with cover or a junction and pull box. Use plenty of wire pulling lubricant when pulling the wire and pull all wires at the same time.
Wire sizes less than 1/0 may not be paralleled. No exceptions.
#6 type THHN, THWN or THWN-2 has an Ampacity of 65 amperes at 75 degrees Celsius.
Old 10-24-10, 10:56 PM
Awesome help! Thanks for the quick reply
Old 10-24-10, 11:11 PM
Thought I once read that when more than 3 wires are utilized in a raceway (conduit in this case), de-rating of ampacity must always be taken into account.
Old 10-24-10, 11:32 PM
They do and the number of % of derate will depending on the numbers of conductors in the conduit and type and tempture { in few case it will affect it }
4 to 6 conductors - 80%
7 to 9 conductors - 70%
But becarefull some local codes may not allow more than 9 conductors { Chicago is one of few spots I know they will go that way }
Merci.
Marc
Old 10-24-10, 11:47 PM
Merci Marc____Hope your in good health. Herb
Old 10-25-10, 01:46 AM
That would be more than three current-carrying conductors. In this example the fourth conductor is the equipment grounding conductor which is NOT a current-carrying conductor execpt under fault conditions therefore no derating is necessary. There are also certain circumstances where a neutral conductor is not considered a current-carrying conductor such as multi-wire branch circuits because the neutral only carries the unbalanced current between the "hot" wires.
Old 10-25-10, 12:38 PM
One techical issue here is that the neutral wire must be white and the ground must be green or bare. The code officially does not allow #6 or smaller wires to be remarked with colored tape; however most inspectors are flexible on this. If the job is inspected I recommend getting the verbal okay first or he could make you pull out the neutral and and ground repull conductors in the correct colors.
Assuming copper and assuming THHN/THWN-2 (please post back if this assumption is wrong). In this case 65A, which you could round up to a 70A breaker if you wanted. There is no need to go above 50A or 60A if that's all the power you need.
Doubling (paralleling) of conductors is not allowed in this case. You could install a second subpanel right next to the first one if you really wanted to use up the free materials. I would probably use what I needed and sell or donate the rest to essentially get a free project done.
