light troubles(flourecencent)
Old 12-16-00, 03:19 PM
Have installed two new fixtures in the kitchen and had everything working before I put up the drywall.When I was cutting out the holes for the lights I hit the tube with the drywall saw and the light quit . Replaced the tube and still does't work the other light works fine and there is power to the second light.Should I have to replace the ballast or what else could it be??
thanks
Old 12-16-00, 05:02 PM
Any chance you hit a wire somewhere with the drywall saw too? Or might you have put a nail or screw into a cable? It seems you must have dislodged or damaged something when you installed the drywall. Test for voltage at the ballast. It's time to start from scratch and test everything.
Old 12-16-00, 05:41 PM
have voltage
Have voltage at the ballast I have burn marks at one of the tube receptacals where I grounded the saw from the tube to the fixture.Power at the ballast also possiable the second tube is bad will replace it and see what happens.Thanks ever so much for your quick response.
