Why is OSB behind drywall?
Old 11-09-10, 11:54 AM
A
Hi,
I have discovered that my garage and bathrooms have OSB behind (interior walls) the drywall. It's flush with the wall studs. My home is a tract home built about 12 years ago.
Why do they do this?
It makes stud finding and putting in old work boxes a real pain.
The reason I'm asking is that I have to change a box to an old work style on a wall with the OSB. There appears to be enough length on the screw for the clamp ears to extend far enough but they typically do a really bad job cutting the OSB hole for the box. On the one I'm working on now the OSB edges are cut at a pretty steep angle so the old work box ears are not holding very well. The drywall hole is a mess also like all the box holes in my house.
Any tips on how to deal with this situation if the ears don't catch short of removing drywall?
Is it allowable to use drywall screws to attach a box to a stud from the inside of the box?
Thanks
Old 11-09-10, 12:35 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You could use a gangable box and Madison clips.
Or you can put sctews through the ears of the gangablle box
Old 11-09-10, 12:43 PM
I
Received 44 Votes on 42 Posts
I'm guessing shear wall for seismic code if you're in California.
You could use "F" clips with a metal box or screw through the box into the stud. Arlington Industries makes a box called "One Box" that can easily be screwed in without damaging the wall.
Old 11-09-10, 01:14 PM
A
Thanks guys,
Just to be clear, what kinds of boxes can madison clips be used on?
Metal and/or plastic old work?
Old 11-09-10, 01:28 PM
ray2047's Avatar
Answer deleted. See next post.
I
Madison clips only work with metal boxes with the plaster ears.
