Manual transfer switch location
Old 11-10-10, 02:37 PM
Terry's Avatar
The instructions say to mount the switch 18" on either side of the breaker box. There isn't an empty spot on the wall at the sides but there is underneath. Is there anything wrong with placing the switch under the breaker box?
Old 11-10-10, 02:52 PM
There should be no problem with that in a typical case. If your panel is in a garage you would not want to have a breaker position lower than 24" from the floor.
Old 11-10-10, 03:20 PM
Terry's Avatar
Thumbs up
Thank you sir. It will be 34" from the floor.
