Problem changing a single pole switch
I'm replacing a single light switch (controls one ceiling can) with a motion-type switch. Anyway the new switch has 4 wires, Black/hot, White/neut. and Red/load, Green/grnd. The wiring inside the wall box has a single cable coming in with the black, white and copper ground.
I'm not sure where this red wire goes if anywhere; I tried capping the red from the switch and the indicator light on the switch lights up but doesn't work, and and no light. I tried capping the black from the switch and that didn't work at all.
Thanks in advance.
Thanks in advance.
new switch has 4 wires, Black/hot, White/neut. and Red/load, Green/grnd.... The wiring inside the wall box has a single cable coming in with the black, white and copper ground
Evidently the RW500U can be used without a neutral; see this link:
http://tools.passandseymour.com/pdf/...evB_IS_eng.pdf
In it, the RWU600U requires a neutral.
Correct on all counts gentlemen, thank you.
Both models were there at the depot, other than the wattage difference, they appeared the same, but I just got back from the return trip and clear as day in microscopic writing, "neutral required..."
The new one is in and working. This place is great, thanks again guys.
