ceiling fans
Old 12-19-00, 09:49 PM
ozzie6
When painting my rec-room
ceiling,I removed the
"Hunter" ceiling fan.In the process,the instructions
became misplaced.It has 2 black wires,1 green and 1 white wire.I need to know what wires to connect to what,to make it work again.
Thanx.
Old 12-20-00, 07:01 AM
s1nuber
We need to know haw many switches you have that control the fan, if there is a light kit, and how many wires are still in the ceiling box.
If you only have one switch, connect black in ceiling box to both blacks in fan, white in box to white in fan, and green in box to green in fan (there may not be a green in the ceiling box, but a bare wire is the same thing).
Good luck.
Old 12-20-00, 07:35 AM
And if you have two switches (one for fan and one for light), the connect the two fan black wires to the black and red wires in the ceiling box (if there is a red). If this changes which switch controls which, you can interchange the black and red.
