Wiring 3-way switch with multiple lights
Having trouble with this 3-way set up. Power is coming in from source to four lights first and then to the two 3-way switches. Here's how I have it wired currently.
12-2 from source, between all lights, and to the first switch. 12-3 between first and last switch. The black from source runs to each light in sequence and attaches to each light's black wire via pigtail. The black from the last light runs continuous through the first switch box and attaches to the common on the last switch. Then red and white travellers run from traveller terminals back to the first switch's traveller terminals. Then white runs from common screw on first switch back to whites on each light, also attached by pigtail. Obviously, since I am posting this, this arangement doesn't work. Any help would be greatly appreciated.
You do not have enough wires run between the fixtures to get this to work.
Is all the work covered or can this be re-worked?
What I gather from the description is that the wiring at light #1 is wrong.
--- is 12/2 and === is 12/3
I assume you have this now:
Power----Light1---Light2---Light3---Light4---Switch1===Switch2
To correct this you need to need to rewire to have power come at Light4, Switch1 or Switch2.
easiest way would be to bring power to either switch one or switch 2. you could accomplish this by running a 2 wire jumper from light 1 to switch 1 or 2. I usually always try and wire my 3 way setups with the power at one switch and the switch leg at the other box.
What you want to do looks like option 6 on this page:
Installing A 3-way Switch With Wiring Diagrams - The Home Improvement Web Directory
If you can have the power source go first to the end 3-way, you would be at option #5 on that page, which is simpler, I think. That's how my basement lights are wired.
Hello yorkbikeman
Here is a fast drawing I made on how to wire up your
project.. I did not draw in all the green equiptment grounding wires
Hope this helps ---
Let us know how you made out with your wiring project
Have A Nice Day
Linesman
Hope this helps ---
Have A Nice Day
Linesman
