NEC Question
Old 12-15-10, 07:57 AM
O
NEC Question
What does NEC say about Wall heaters and dedicated circuits??
I have a 500 watt fan i want to put in a laundry room. I have a 20 amp GFCI circuit with 3 outlets on it and could be dropped to 2 outlets if need be. Can I use this or does it have to be dedicated??
Does it need t be thermostatically controlled??
Old 12-15-10, 09:15 AM
T
What kind of wall fan do you have, 110V or 220? I'm quite sure it will need to be on a dedicated 20 amp circuit.
Old 12-15-10, 09:51 AM
I
Received 43 Votes on 41 Posts
A fixed-in-place appliance needs a dedicated circuit if it consumes more than 50% of the circuit ampacity. A 20A circuit can supply 2400W, so you would not need a dedicated circuit for a 500W heater. However, if this circuit also supplies your washing machine you might trip the breaker during the spin cycle.
Heaters are generally best on dedicated circuits even when it isn't strictly required to do so.
Old 12-15-10, 05:46 PM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
Yes, there needs to be a thermostat to control this heater. It can be on the heater or a wall thermostat.
Old 12-15-10, 06:53 PM
Tolyn Ironhand's Avatar
Received 205 Votes on 182 Posts
Well......it doesn't HAVE to be on a thermostat. But then you would have run away heat.
