Conduit help!!!!!
Old 12-22-10, 06:15 PM
Conduit help!!!!!
When the conduit goes through the metal roof (between the load center and the weatherhead), how do you keep it from leaking?
Old 12-22-10, 06:37 PM
ray2047's Avatar
You need to use a roof jack designed for your type of metal roofing. You might want consult a roofing supply that handles your type of metal roofing.
Edit: See Chandlers reply. Post #4.
Old 12-22-10, 06:54 PM
Tolyn Ironhand's Avatar
If you buy your weather head as a kit it should come with the flashing as well. Ray's picture is pretty good but the ones we use have a rubber gasket where the flashing meet the pipe. You will also need to slip the top (high side of the roof) under your shingles.
Old 12-23-10, 03:41 AM
chandler's Avatar
But he is dealing with a metal roof, Scott. #3 MASTER FLASH RED SILICONE PIPE FLASHING, SQUARE-BASE may help in knowing what you need. Most metal roofing supply houses carry the jacks. You just form them around the raised areas if they are in the way.
Old 12-23-10, 10:35 AM
Ooops! Missed that. Sorry.
