Wiring Help
Old 12-26-10, 08:17 PM
Wiring Help
Is there any reason I can not run wires from the load center to its circuit, in the roof trusses?
Old 12-26-10, 08:36 PM
You need to be more specific. What are you trying to do? Are you talking about adding fixtures/receptacles to the attic? Or, are you talking about adding circuits to existing jboxes?
What's your main panel amperage? What are you trying to run?
Old 12-26-10, 08:57 PM
I'm talking about ALL the wiring in the house.
Old 12-26-10, 09:50 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Are you wiring the house from scratch? Are these manufactured trusses. Can you post a few pictures and give us more details about what you are doing.
Old 12-27-10, 06:19 AM
Received 7 Votes on 7 Posts
Attic Wiring
Be sure to secure the electrical cables in such a way that the cables will not be in contact with the metal truss connectors to avoid damage to the cable insulation. Keep cables at least six feet away from attic access openings.
Old 12-27-10, 10:02 AM
Yes Ray, this is wiring from scratch, and yes I'm usuing manufacured trusses. Thank You, for your reply.
Old 12-27-10, 10:51 AM
Justin Smith's Avatar
I do not see a problem with running wires in the attic, just staple them away from sharp objects. There are also cable ties with a hole to screw them to the stud for larger bundles that would look a little more professional, as compared to 20 wires stapled in a row. It would also be adviseable to use 12awg for receptacle circuts as you could put more of a load on while not tripping the breaker.
Old 12-27-10, 11:16 AM
Received 59 Votes on 55 Posts
This would be true if you used 20 amp breakers instead of 15
Old 12-27-10, 05:19 PM
Received 42 Votes on 40 Posts
There can be issues with running wiring through trusses in the attic. First you can only use the factory holes in them, as cutting or boring them reduces the strength beyond design limit. Second, you will run into a derating issue if you bundle too many cables through one hole. Generally you cannot exceed 4 cables through one hole for normal 15A and 20A circuits. Other circuits have lower limits. Finally, if your attic is accessible the wiring will need to be protected from damage, which may require you to install running boards or similar to prevent damage from footsteps or storage.
Old 12-28-10, 07:08 AM
chandler's Avatar
Received 3 Votes on 3 Posts
As Ben says, running a raceway (2x6 with 2x4 side walls) will allow you to run circuit cabling en masse along the trusses, and just jump out when the circuit terminal location is reached. If left to access, you can cap off the raceway with a 1x8 with screws so it will remain accessible but virtually indestructible by walking on it, etc. Sort of like building a wooden conduit.
