Reload this Page >
leaving 240v electric range/stove outlet behind cabinets with a longer cable?
Old 12-28-10, 10:16 AM
newbie here and first post.
I'm remodeling my kitchen and the stand alone electric range/stove needs to be moved about 3 feet away from where the the 240v (4 wires) receptacle currently is.
I've seen 4 different contractors and they all telling me just run a longer range/stove cable under the cabinets to where the outlet is and leave the outlet behind the cabinets (while cutting out a section so the plug has room)
Is that really ok? will it gets too hot and burn the cabinets?
Old 12-28-10, 10:38 AM
They are saying to buy a longer range cord? That should be no problem at all if they're sold in different lengths. I don't see any problem with heat buildup.
Old 12-28-10, 10:43 AM
yup a range cord. I was recommended to get a 10ft.
i guess i'll not have them move the outlet and just install the cabinets over it.
Thanks for the reply!
Old 12-28-10, 11:20 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
AFAIK Range cords are not intended for use as concealed premises wiring. That sounds like what they are suggesting.
However if you run the cord through the cabinet not under it that would be ok. You could put hooks up high in the cabinet to rest it on.
Old 12-28-10, 11:28 AM
Received 6 Votes on 6 Posts
Range Receptacle
Check the height of the range receptacle above the floor. Will it be high enough to be above the cabinet floor?
Old 12-28-10, 11:35 AM
The bottom of the cabinet will need to be cut in order for the plug to fit.
The reason I'm running the cord under the cabinets because i'm using ikea cabinets. they sit on these legs which gives me about 4" off the tile floor. I can always pop off the kick board and snake the cord out if it needs to be replaced.
is that ok?
Old 12-28-10, 11:56 AM
ray2047's Avatar
Given the cost of a longer cord I'm wondering why you don't just move the receptacle. Is there some special problem like lack of access. Seems beter then butchering the cabinet.
An inspector might give you a hassle but seems ok to me. Wait for the pros' opinion.
Old 12-28-10, 12:42 PM
Food for though here...if you have a 3 wire cord I remember Carol Cable used to make a 10' cord.....however 10' cords were not UL listed.....I have never seen a 4 wire 10' cord, so you may have to make it either way as a 10ft cord will be diffucult to find in stock anywhere. Standard range cords are 4' and 6' 3w or 4w. I would move the receptacle myself if it is practical.
Old 12-28-10, 12:51 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Per the link posted earlier..$21 for a UL listed 10' cord....
Not my preferred method...but way cheaper than an electricians bill for the move.
Old 12-28-10, 12:55 PM
Well, I posted that link, but upon further review, I see the following, which seems contradictory:
Product Description
From the Manufacturer
4-wire range cords are 10 feet in length and are 50 Amps and are not UL listed.
Product DescriptionPETRA 90-2088 4-WIRE RANGE CORD - 50A (CLOSED EYELET) (10 FT) CLOSED EYELET; 50A 250V;UL LISTED & ISO 9002 CERTIFIED; BULK PACKED;1/12;10 FT
Old 12-28-10, 01:42 PM
Justin Smith's Avatar
If it were my house, I would move it.
Old 12-28-10, 06:58 PM
CasualJoe's Avatar
Received 38 Votes on 30 Posts
You are spending a lot of money to install all new cabinets. Why not just spend a little more and do it right? I'm sure you'll be happy you did once it's all completed.
