Safe to Drill Through Engineered Beams?
Old 01-01-11, 11:25 AM
Justin Smith's Avatar
I was at a friend's house and they want to install some can lights. They have engineered I beams instead of 2x8's. It is a strip of plywood glued to two 2x4's. Is it safe to drill through them to run some 12/2 or 12/3, or do I need to reinforce/rerout wires?
Thanks,
Justin
Old 01-01-11, 11:32 AM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Yes. Only make your holes in the plywood part of the I joists. No reinforcement is necessary. Many cases the I joists have pre-scored parts that you can punch out with a hammer.
Old 01-01-11, 11:35 AM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
There should be marked areas/knockouts for running wiring and piping. If the knockouts aren't visible/accessible, I can't imagine the size of a hole for a single cable would be a big deal. Use the same rules as drilling any structural member.
http://www.ilevel.com/literature/TJ-9001.pdf
Old 01-01-11, 12:32 PM
pcboss's Avatar
Received 32 Votes on 27 Posts
This does not sound like an engineered beam, but an engineered floor joist . There is quite a bit of difference and will determine of they can be drilled. Typically engineered beams cannot be drilled, while the joist can.
Old 01-01-11, 03:23 PM
You can drill the web on an I joist but not the flanges. There are lots of charts on the internet that provide directions for drilling I joists.
Old 01-01-11, 04:14 PM
chandler's Avatar
But, like Vic says, they have coordinated knock outs. All you have to do is hit them with a hammer, and they're gone. The manufacturer put them there, so they are OK to use for wiring, small supply lines, etc. BUT, as I have seen many times, they cannot be cut to accommodate HVAC without proper support. 9" web, 8" duct just don't work at mid-span.
Old 01-02-11, 06:52 AM
Check the local codes too. One town in our area says you can't drill farther than two feet toward the center from either end, and there is also a restriction on hole size. (Don't quote me, but I recall 2".)
Old 01-02-11, 10:59 AM
tHEY ARE ENGINEERED FLOOR JOISTS, THERE WERE NO LOCAL CODES WHEN THE HOUSE WAS BUILT, AND i THINK THEY ARE STILL VERY LENIENT. i ONLY NEED TO RUN ONE 12/2G OR 12/3G, DEPENDING ON WHERE WE FEED POWER FROM, SO i WILL ONLY DRILL A 1/2'' HOLE. i WILL HAVE TO CHECK FOR THE HOLES.
Old 01-02-11, 12:55 PM
Check your caps lock key.
