After replacing, light switch does not operate wall outlets.
My living room has 1 light switch and 4 wall outlets. One outlet socket (I think the top) was operated by the light switch. The other socket was always On. I replaced all outlets and the light switch. Now all my outlets are always on and the switch does nothing.
I called a local hardware store and he said to break the metal tab on the side of the hot wires on the outlet. So I broke the tab between the red and black wires of one outlet. Didn't fix it. So I did the same on the other 3 outlets. Still didn't fix it. Any ideas of what I did wrong? My theory is that I might have switched up the 2 white wires on some of the outlets. Could that be the problem? Thanks, -Troy
Tell us how many 2-conductor cables and if any 3-conductor cables in the switch box. Tell us how they are connected.
I turned off the power and unhooked all 4 outlets. On 3 of the outlets there are two black wires coming from the wall and they join together so that one black lead goes to the outlet. On those same 3 outlets the same is true for the red wire. Two red wires come out from the wall and join together so that one red lead goes to the outlet.
However, on the 4th outlet there is one black wire coming from the wall that connects directly to the outlet. There is another black wire coming from the wall that joins with a red wire coming from the wall to make a red lead that connects to the outlet.
The 2 wires that connect to my wall switch are 1 black and 1 red. The light switch seems to control the black wire on the outlets.
So, what to make of this? Do I need to break the tab on the brass side of the outlet on all 4 outlets? Currently 3 of the outlets have the tab broken and 1 has it non-broken.
Didn't get any feedback and I was pretty confident I was correct, so I removed the tab on that last outlet and that fixed it. It seems the problem was that the wall switch controlled the bottom socket(black lead) on all 4 outlets and by having 1 outlet with the tab still connected caused it to be one large circuit with the top socket and always On. By removing the tab on that last outlet it broke it into 2 circuits and the wall switch controlled the bottom socket circuit. Thanks, -Troy
Very good, Troy. You solved a problem that might have even caught a pro. Normally only one receptacle has the switched half. Thanks for letting us know.
Following is opinion only. I would not want half of the receptacles switched. Too many things today that need constant power. I'd probably wire it so only one was half switched.
Thank you Troy!!!
I could not figure out why my switch wasn't operating my outlets and it was indeed the fact that ALL the tabs on the hot side for EACH outlet in the room was not snipped... thanks again for helping me figure it out!
Jim
Jim
