Splicing stranded to solid wire
Old 01-06-11, 10:03 AM
Does the NEC prohibit tinning the end of stranded fixture wires before making the wire nut connection to solid house wire?
Old 01-06-11, 10:28 AM
Received 42 Votes on 40 Posts
Stranded fixture wires may be tinned if you want. Usually a plain wirenut connection is sufficient if you strip the stranded wire a little longer than the solid wire and set it a little past the end of the solid wire before threading on the nut.
Old 01-06-11, 10:43 AM
pcboss's Avatar
Received 40 Votes on 35 Posts
No NEC prohibition that I can think of, but unnecessary IMO. Ben has given a good method to make a secure splice.
Old 01-06-11, 11:23 AM
Received 62 Votes on 58 Posts
I've always done it the way Ben said, never had a problem
