Lights not working jumped nuetral?
Old 01-09-11, 07:26 PM
I had some lights not working.I looked at the switch and put a tester on the hot and neutral wire I did not get a reading(switch was on).
I touched the neutral wire and screw to the metal on the switch itself and the lights came on and stayed on.
What is wrong this is scary.
Old 01-09-11, 07:28 PM
Received 42 Votes on 40 Posts
It sounds like you have a broken or burned off neutral wire upstream in this circuit. It often happens at a bad backstab on a switch or receptacle, but could be in a wirenut or crimp.
Old 01-09-11, 07:35 PM
Been a long time since I done electrical.What I meant to say was I touched the other hot wire to the metal(the one going to the light) and the lights came on. Upon futher testing the nuetral wires that is wire nutted together in the box is hot.
Old 01-09-11, 08:01 PM
Forget everything I just said.
The problem is just I touched the hot wire screw on the switch to the metal on the switch itself and the lights came on and stayed on.
The hot and neutral wire tied together was actuall the hot wire from the junction box.
Old 01-10-11, 10:22 AM
Okay, lemme see if I've got this right before we proceed.
The switch has a black and a white wire on it. You removed the white from the switch and touched it to the metal box and the lights came on?
Also in the box are a black and a white, wirenutted together?
Also in the box are bare ground wires, connected to a screw on the metal box?
