Replacement Lamp Socket (Shell Only)
Old 01-18-11, 07:26 PM
CircuitBreaker's Avatar
Received 5 Votes on 5 Posts
Question Replacement Lamp Socket (Shell Only)
I have a lamp that I really like but the shell of the socket is broken (The socket part that holds the medium base lamp is fine) It is a newer lamp that uses the three piece black plastic shell with the actual socket being the third piece. Anyway where can I get one and what is the proper name for this item? All of the lamp parts sites I saw only have the traditional style of socket (The standard brass or nickel plated metalized with a paper liner)
Thanks
Edit:
Here are some pictures of the part I am in need of
Old 01-18-11, 09:15 PM
Getting to the point that a lot of new items are OEM only for parts but your looks like possibly a Leviton product. See if this link works, check out Leviton 95080, 95119, or 97092. hard to say who might stock these but you should be able to special order one from your nearest Leviton Distributor. I doubt they sell the shells only on these as they do the brass and nickel ones, but the cost would little difference anyway. Still might be OEM item (only available from lamp mfr.) but I really think one of these will work.
Standard > Shell Lampholders > Incandescent > Lampholders > All Leviton Products from Leviton Electrical and Electronic Products
Old 01-18-11, 09:51 PM
So now that I know that they are called Phenollic I just found this
Lamp Sockets - PHENOLLIC SOCKETS - TX Lamp parts
TR-34 is what I need
Thanks
