Replacement GE Safety Breaker "Deadman" Panel
Old 01-19-11, 07:59 PM
Know this is worse than a needle in a haystack, but looking for the breaker cover for a 30 year old GE residential 200 Amp panel, model TM202MUF Mod2 with the breakers down the right side and the meter mount and main breaker on the left side. The actual deadman panel is close to 29.75" high and 6.25" wide. Hoping someone might know of an electrical scrap yard, recycler or other source.
If not, I will grab a piece of 16 ga sheet metal and fabricate one but with the vast resources of DIY, thought it worth asking...
Old 01-20-11, 10:10 AM
Received 42 Votes on 40 Posts
This type of place should show up in your yellow pages if you have one in the area. When I need an odd panel cover I usually have one of the local metal fab shops whip something up and hit it with a coat of battleship enamel.
Old 01-20-11, 10:21 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Just a suggestion. The one time I did this I made a template using foam poster board. Easy to work with and you can afford to throw away your mistakes. Once it is perfect then you can make the metal one or have a shop fabricate it.
