Reload this Page >
Do you need to plug the ground cable on something like a motion sensor if...
Old 01-24-11, 10:26 AM
Do you need to plug the ground cable on something like a motion sensor if it's going to be grounded anyway by contact of the motion sensor's case through the screw to the grounded wall box?
I normally do it anyway, but is it necessary since it's already grounded by contact to the grounded box?
Thanks
Old 01-24-11, 12:06 PM
ray2047's Avatar
What do you mean by ground cable? Do you mean ground wire from the device? All ground wires must be tied together and if the box is metal pigtailed to the box. A ground wire must be attached to any device not listed as self grounding. When used in a plastic box self grounding devices must have a ground wire.
Old 01-24-11, 01:31 PM
It is a fairly recent addition to the NEC that switching devices must be grounded directly, even if they are screwed to a metal box.
