Through or Under Studs
Old 01-26-11, 08:16 PM
G
I'm running several new circuits from a 2nd floor unit to the break panel. The new circuits will span half the basement.
Do I need to drill holes in the joists, or can I staple the cables to the underside of the joist?
This is not the kind of basement that will ever be remodeled.
Thanks.
Old 01-27-11, 05:40 AM
W
Received 7 Votes on 7 Posts
Circuits
What size wire? The answer to this determines the answer to your question.
Old 01-27-11, 08:05 AM
I
Received 42 Votes on 40 Posts
If you don't go through the floor joists, you need to nail a running board like a 2x4 to the underside of the joists that you can staple the cables to. Standard size cables cannot be stapled to joists unsupported.
Old 01-27-11, 09:59 AM
B
"Standard size cables cannot be stapled to joists unsupported."
I thought 14-10 g could be stapled without running board?
Old 01-27-11, 11:30 AM
I
No, a cable must be #8 or larger to be stapled unsupported.
Old 01-27-11, 03:04 PM
G
Sorry, I always forget a few details....
I'm running #12. The only reason I ask is because the joists are quite old and don't look 100%. I'm probably being overly cautious, but why not ask right?
Old 01-28-11, 07:11 PM
pcboss's Avatar
Received 42 Votes on 37 Posts
The code is concerned that the cables could be used as a clothesline and the staples could damage the cables.
