GFCI install is driving me crazy....
Old 02-07-11, 04:31 PM
Here is the run down: My daughter was using the vacuum and had it plugged into the plug in the bathroom (a GFCI plug), this has been done many times before just so happens this time all power went out in hall,3rd bedroom and bathroom. Since it would not reset I bought another one and followed the installation steps to the "T" since electricity is silent but deadly.Now my issue is the receptacle wont reset, it has power going only to the line wires but not the load wires. Any and all HELP is GREATLY appreciated.
Old 02-07-11, 06:40 PM
CasualJoe's Avatar
A GFCI outlet won't reset if you don't have proper power to it. Have you checked voltage hot to neutral? Either there is a problem with the line voltage or it is wired wrong.
Old 02-08-11, 08:53 AM
I will almost guarantee that you have a burned off wire somewhere else in this circuit. Vacuum cleaners draw a lot of current which can cause weak connections to burn through over time. If you can measure voltage from hot to ground, then the burned off wire is probably a white (neutral) wire.
The fix is tedious, but straightforward. You have to visit each receptacle, switch and light fixture on this circuit and thoroughly check each device, crimp and wire nut for bad connections. Move any back stabbed wires to adjacent terminals, replace any devices that are worn or damaged. Remake wire nut connections (sometimes you can't see the break inside the wire nut). The problem is most likely at the working device or first non-working device on this circuit.
Old 02-11-11, 06:24 AM
Have you checked to make sure you dont have line and load reversed? Depending on the manufacturer, some GFCIs will also not reset if line and load is reversed.
Old 02-11-11, 09:26 AM
pcboss's Avatar
The revised standard applies to all manufacturers. All new GFIs should not reset if wired improperly.
