1965 outlet wall plates - WEIRD shape
Old 02-17-11, 09:49 AM
E
Hello,
I bought a condo built in 1965 and the wall plates were old and painted over, so we threw them away. Big mistake as I can't find any replacements. They are an odd shape with the outlet running horizontally and a phone jack (shaped like a circle) on the horizontal end of it. Instead of the more square covers you find today, the shape I need is a long thin rectangle. Any suggestions on where to find a cover for this? I don't want to have to drywall over all the phone jacks; a future owner may be interested in having a landline if they're still around in 5 years or so!
Thanks!
Old 02-17-11, 10:19 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
While probably grandfathered but if there is no divider between phone and receptacle it is a violation of current code. The round 4 prong jacks are obsolete though adapters can probably be purchased. I'd probably replace with modern old work box. Only a small bit of repair needed if you installed then horizontal using existing box. I wouldn't worry about future occupants but that is just me.
Can you post a picture or two? http://forum.doityourself.com/electr...your-post.html
Odd to have that many jacks. Are you sure they aren't for a whole house vac system?
Old 02-17-11, 10:26 AM
ray2047's Avatar
Just a note I moved your post. Fits a bit better in electrical.
Old 02-17-11, 11:58 AM
A
Is the phone wiring in a separate box, box with divider, or same box?
As already mentioned, a photo would help.
Once you have a photo, you might also check with Mike Sandman ... he's probably seen one. Mike Sandman... Chicago's Telecom Expert Home Page
Old 02-20-11, 10:53 AM
Old 02-20-11, 11:07 AM
ray2047's Avatar
Excellent link. Thanks for posting.
Unfortunately the OP never posted back so the mystery may always remain a mystery.
