Reload this Page >
Need to buy what is needed to add a 220 line for new stove
Old 02-17-11, 04:40 PM
BAMencer's Avatar
Smile Need to buy what is needed to add a 220 line for new stove
Hi gang,
I bought a new electric range for my wife and the house is set for gas. The location of the stove is almost directly above the breaker box which is in the basement below the kitchen. I figure I need to get wire, conduit, the outlet and a breaker. I would guess 6-3 wire and a 50 amp breaker...is that correct? I will have an electrician do the work.
Thanks
Old 02-17-11, 05:02 PM
I ask why would you go from gas to electric?
Old 02-17-11, 05:09 PM
Tolyn Ironhand's Avatar
6-3 NM-b and a 50 amp breaker is correct. Conduit is not needed if you use NM-b. You will also need a 4 wire, 50 amp, 250 volt receptacle and a 4 wire cord for the stove if one is not supplied.
Some people just don't like cooking on gas.
Old 02-17-11, 05:19 PM
If you're having an electrician do the work, likely he will bring the supplies needed. It's rare for an electrician to want to use supplies that were purchased by someone else. Just be sure before you buy everything.
Old 02-17-11, 05:25 PM
CasualJoe's Avatar
I usually recommend consulting the range's installation manual for the recommended circuit sizing. The last new Whirlpool self cleaning electric range I bought for my own home specified a 40 amp circuit. A 40 amp circuit is what was in the house when we moved in and it has been operating that Whirlpool range a long time with no problems.
Old 02-19-11, 08:10 PM
BAMencer's Avatar
Thanks for all the advice. Electrician will bring in his stuff...duh on my part.
BTW, switching to electric for the smooth cooking surface.
Old 02-19-11, 08:42 PM
Yes my wife likes those smooth glass tops also. Easy to keep clean. Enjoy your new stove.
