Some lights plugs not working
Old 02-19-11, 04:41 PM
Exclamation Some lights plugs not working
Hello this is gonna be a long read but will do my best to make it short and try and cover all the details.
I live in a older mobile home There are no GFI plugs.
Other night i was in the living room area watching tv and working on my pc when all of a sudden the power to it went off so i figured a breaker tripped i went and looked the only breaker that was in tripped was on that went to a old furnace that has been disconected and capped off this breaker is usally switched off any way i flipped it on to flip it back off and it sparked and made a very loud arcing sound and all the lights went out .
I toggled the main nothing went out side and checked the main breaker on the pole wasn't tripped I toggled it any way went back inside and tried main and power came back on came back on Except the plug tv goes to and 2 back bedrooms
I removed the breaker at the bottom that arced and it was burnt you could smell it
I checked the surge protector and it smelled burnt also so i un plugged the TV and DVr and plug in to wall socket. Still nothing also two back bedrooms had no power either.
It was late and so i planned to check it better in the morning anyway about 20 mins later the tv and lights in other room just came on they worked well a couple days later the lights in the main bedroom and living room start flickering it lasted about a few minutes
Today the power to the tv and back bedrooms went out again i reset breaker several times nothing. I went to the store and got a new breaker and a volt tester
i put new breaker in Still no power to the one plug and two rooms
I tested the wires leaving breaker both have power it is a double 15 amp breaker
the top when its off the plug on the left side loses power the bottom turns off right and the ceiling fan.
I removed the plug from wall it is only hooked up by it self no a daisy chain
Can anyone help me here why lights went out the came back on now out again
I can not afford to call a service guy and i know enough not to fry myself i just need to know what to start on
Old 02-19-11, 05:55 PM
Update>>>>>>>>>>>>>
I read around some more anyway long story short i went to the outlet that was still working and checked it was getting power i still went a step farther and pulled it from the wall one of the white ground wires was burnt inside of the plug.
I trimmed the wire back and wired black to black white to white and flipped the breaker all the lights came on
I then hooked it up to a new plug but now when i flip the breaker it auto trips can you wire a plug up wrong how should it be wired
Old 02-19-11, 07:26 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Can you explain this a bit more. Black goes to the brass screw and white goes to the silver screw. Is that what you mean?
Old 02-20-11, 02:42 PM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
Also, OP said this is an older mobile home. How old? Is the wiring aluminum?
