A novice rewiring 1940's build house
Received 0 Votes
The house I am rewiring was built in 1940's and came with one 30 Amp
breaker in the sub panel. Since then, the local electric company upgraded the main panel to 240v; the house still had 30 Amp circuit breaker. Now I have upgraded the sub panel to 125 Amp sub panel and rewired the house
with Romex 12/2 NMB wires.
My question is this - to rewire from 220 v Main Panel to sub panel,
what are my choices besides Romex SER #1 (rated 130 Amp) ?
Can I use Romex SER #2 (rated 100 Amp) ?
My heater, dryer and stove is all gas, so don't need 30 Amp breakers.
Thanks
HP
Thanks
HP
Does the subpanel have all the circuits for the house in it? Is there a main breaker somewhere?
What is commonly called Romex is technically type NM-B cable. It is not the same as type SE cable. Both can only be used at the 60 degree rating so your ampacities are incorrect. We would also need to know the conductor material.
Received 0 Votes
Thanks pcboss for replying.
Yes the sub panel have all the circuits for the house. The main
breaker is outside the house, next to the SDGE meter panel, but
I was told to bring in the shut off breaker (100 Amp) to the sub panel.
I saw Romex 2-3 NMB at Home Depot, but it's rated only 95 AMPS;
I spoke to a commercial electrical supplier, and she said I should go with
Romex 1-2 SER (copper), rated upto 130 AMP, since my sub panel is
125 AMP.
BTW, what do you mean by "60 degree rating" ???
Am I making any sense yet ?
I am so embarassed to sound so dumb!
125 AMP.
So the 30 amp panel no longer exists, correct? It was replaced with the 125a panel Correct?
Ok, how close is the main panel to the subpanel? If 5'* or less I'd just run conduit on the outside of the house and use three individual 1/0 THWN individual conductors and one #6 for ground. Sizes refer to copper.
*If your OK with appearance the conduit could be run as far as needed on the outside wall.
Received 0 Votes
Ray2047, thanks for replying.
Yes you are correct that the 30 amp sub panels has been replaced by 125 amp sub panels
(duplex).
According to a electrician, even with 125 amp sub panel, I can go with 100 amp breaker/100 amp rated Romex #2 for each of the duplex, since that should be plenty. Of course they would be run through the attic/crawl space.
Thanks
What are your thoughts?
(duplex).
Thanks
That is correct. The copper #2-3/g NM-B romex should be protected in the attic by running along a framing member or 2x4 running board. You could also use #2 copper SER (four conductor).
