Adding an outlet
Old 02-27-11, 01:19 PM
Adding an outlet
My living room has one interior wall that is brick (must be a 70s thing) with a single outlet smack dab in the middle. I am going to put up a real wall (studs & drywall) and would like two outlets about 1/3 and 2/3 of the way from the adjacent wall, doing away with the current centered outlet. Can I run the two new outlets off the feed from the existing outlet, then cap it off?
Old 02-27-11, 01:53 PM
pcboss's Avatar
The old circuit would need to contain a ground in order to extend the circuit. The junction box to the old wiring would also need to remain permanently accessible.
Old 02-27-11, 04:22 PM
All the house wiring is 2 wire w/ground. Maybe I will just add an additional outlet. Seems silly to cap this one off if the box has to remain accessible.
Old 02-28-11, 08:49 AM
You will also need to comply with modern code spacing requirements for receptacles on this new wall which means you need a receptacle no more than 6' from any edge and no further apart than 12'.
