Replacing a ceiling fan Question
Old 02-27-11, 03:30 PM
Hello, I was hoping someone with knowledge could validate the ceiling fan work that I did, or tell me if I did something glaringly wrong. My project was to replace a ceiling fan in my kitchen.
Upon removing the old fan I realized that a proper box had never been used, Existing was a 1.5 inch deep box attached to the joist with a piece of scrap wood. So I first removed that and installed a Westinghouse Side Mount fan box with four lag screws to the ceiling joist.
I live in a 1950's colonial with updated wiring, but this particular circuit still contains know and tube, thus there were only two wires coming into the box. When I trimmed back the existing wiring before installing the new box I trimmed it a bit too short to adequately work with (only 1 - 1.5 inches coming into the new box), so I need a pigtail. It's a 15 amp circuit, so I pigtailed both the hot and neutral wires with stranded 14 AWG properly color coded wire and secured with a wire nut and electrical tape. The old insulation from the knob and tube terminates upon entering the electrical box. There are now 5 wires in this 2.5 inch deep box, 3 hot and 2 the two neutrals. There is no ground, so I just secured the 2 grounds together and placed in the box.
I just am trying to confirm that I did not make any glaring mistakes, so any feedback is definitely appreciated. Thanks.
Old 02-27-11, 07:30 PM
Tolyn Ironhand's Avatar
From your description, your installation is correct. When doing your wire count for box size you do not count the wires that do not leave the box. IE: The pigtails are not counted for box fill.
Old 02-28-11, 06:56 AM
Tolyn, thanks so much for the quick reply and information. Much appreciated!
Pete
