How to wire an outlet for a 3-prong range plug
I am replacing my range and discovered that the existing range was hardwired in. I have the following existing wires form the panel; black, black w/red stripe, grey, and a bare wire. I bought a Leviton 50A surface mount outlet (50A-125/250V) (3-pole, 3-wire non grounding power outlet). The problem is that it doesn't have a place to connect the bare wire. Do I have the correct outlet? What do I do with the bare wire? The stove I am replacing it with has a 3-prong plug on it.
Thanks for any help you can give me!!!
The cord set on your stove needs to be changed to four prongs according to manufacturer's instructions. This generally means removing a bonding strap or wire from the neutral.
You never change a 4 wire range service receptacle to 3 wire. You always change the cord set to four wire. Four wire is safer.
Thanks alot for the info.!!! I was hoping I didn't have to change out the range cord since this house was built much earlier then the house I got the replacement appliances out of. I didn't look at how the original range was wired when I took it out. I'll proceed with changing to a 4-prong outlet and range cord. Thanks again.
John
John
