Dose a sub w/in 3' of main need its own breaker?
Old 03-01-11, 12:23 PM
Does a sub w/in 3' of main need its own breaker?
I no longer have access to NEC online, thanks NFPA I was working on installing a subpanel but have gotten so side tracked... its within 3 feet of the main and the question is: Does the subpanel need its own breaker when there will be a breaker in the main panel from which its fed?
Thanks!
Old 03-01-11, 12:27 PM
No. Any subpanel in the same physical building as the main panel from which it's fed does not need a main breaker. How's the workshop coming along?
Old 03-01-11, 12:28 PM
Hey, ib, thanks! Dreadfully
NO breaker in the sub panel is needed in this setting.
Jim
Old 03-01-11, 12:37 PM
That's too bad! Good luck getting it done and look forward to seeing the final product eventually over on WTO.
Old 03-01-11, 03:02 PM
Words of encouragement Ben What does "WTO" stand for?
Old 03-01-11, 03:25 PM
The Wood Talk Online forums. I'm over there occasionally and I remembered reading your shop building thread about the same time your electrical thread was going on here.
Old 03-01-11, 05:56 PM
Ah! Wonderful!! Fellow woodworker? Money and time have conspired against me... still working at it though. Going to start another thread about fluorescent light units.
Old 03-02-11, 09:13 AM
When I get the time and money to...I understand that.
Go with high frequency electronic ballast T-8 or T-5 fixtures and install "daylight" lamps. The lamps color temperature should be at least 5000K and CRI (color rendering index) 85 or higher; this will get you as close to natural sunlight as you can get with artificial light. The ratings of the lamps make a huge difference in the quality of the light so don't skimp on those. You should be able to get basic fixtures for [email protected] and lamps about [email protected] or cheaper if you need enough to buy a case. They have good output, high-efficiency, cold start and no hum. Do not bother with T-12 at all, they are ancient technology and the hum will drive you crazy. (BTW, the diameter of the lamp is measured in 1/8 inches. T-12 lamp = 12/8" = 1.5" diameter)
