Trouble Wiring Replacement Fixture
I am replacing a light fixture and having trouble with properly rewiring the new fixture.
The fixture has a two wire cable (black, white) and three wire cable (black, white, red) coming into the box.
The power is coming from the two wire side.
The circuit has two 3-way switches. My assumed sequence is power supply, fixture, switch #2 and switch #1.
Switch #1 has three wire cable leaving the box. Switch #2 is in a box with 2 other switches. Switch #2 has a red common, 1 black and 1 red travelers.
Advice for properly wiring the fixture to allow the 2, 3-way switches to work properly would be appreciated! Thanks for your time.
The red traveler in Switch #2 has a bit of white on it, but it appeared to me to be paint rather than an intentional marking.
The common from Switch #1 is red, I believe. It's a dimmer switch so not as crystal clear. No-recolored wire.
There is only the one 3-conductor cable in the box for Switch #1. The box for Switch #2 has 3, 3-conductor cables, one at Switch #2 and one at the other two switches that do not control the fixture in question.
There is a 2-conductor cable in the box for Switch #2 (4 conductors in total). The black goes to one of the other switches and the white is pigtailed with wire from 2 of the other 3-wire conductors entering the box.
Thanks for your help!
