Problems after replacing metal box
Received 0 Votes
Good afternoon,
I am looking for help with a problem as I am a total newbie to electrical projects.
Here is the scenario: I had an existing metal box which has metal conduit attached to it from bottom and top. Bottom contains the hot wire which then feeds recessed lights on top.
I replaced the existing wall switch with a new one and later found that it would not fit in the existing metal box. I bought a deeper plastic box and replaced the metal box with it. After this, the recessed lights did not turn on. I noticed that my "pen" voltage tester now detects current throughout the metal conduit leading up to the recessed lights. I am assuming that by removing the metal box, I lost ground? Problem is that there are only two wires and no ground wire in the conduit.
Any clues on what is going on?
Thanks,
Angel
Thanks,
Angel
You can not replace a metal box with a plastic box if metal conduit. It is not code compliant.
Non-contact testers are prone to false positives.
That is why a plastic box is not code compliant.
Also as Ray said, you need to change the box back to metal. Metal boxes are available in a variety of depths with a variety of mud ring depths also.
Now that is a major problem. The conduit needs to have a complete set of circuit conductors (hot and neutral) or be a switch loop (hot and switched hot). I can't think of any situation where a conduit with one conductor would be safe or legal.
