Is this a common neutral - is it allowed???
Old 03-07-11, 05:44 PM
Arrow Is this a common neutral - is it allowed???
Hi,
I'm changing a circuit and going from 15A to 20A, so I'm rewiring it with 12ga NMW.
There was a ceiling light box being fed from a receptacle and then feeding two switches in one box for two different ceiling lights. The feeder from the ceiling light was using a 3 wire cable with a "common neutral" for each light switch and the red as the positive for one switch and the black for the other.
Since I'm replicating this part of the circuit in 12ga, I want to be sure I can do this or not.
It's all one breaker, so is that allowed or do I need to run two 2 wire cables from the ceiling box? Is it safe?
Thanks guys.
Old 03-07-11, 05:58 PM
pcboss's Avatar
Received 35 Votes on 30 Posts
I do not think you are dealing with a neutral. I think you have 2 switch loops in one cable. The white should have been re-identified as a hot conductor and feeds power to both switches. The black and red are two switch controlled hots.
Can you confirm if the white connects to both switches?
Old 03-07-11, 06:02 PM
Justin Smith's Avatar
It is perfectly legal. That is often done for ceiling fans with sepreate light/fan control, and there is one in this very room.
Old 03-07-11, 06:08 PM
Tolyn Ironhand's Avatar
Received 68 Votes on 60 Posts
Just for future reference there is no "positive" in AC wiring. There is hot (your "positive") neutral and ground.
From what you describe they have two switch legs and one neutral. This is 100% fine. I would wire it the same or run two cables if you wish. Either way is fine as long as you box can handle the extra wires at the larger size cubic inch wise.
NMW? You must be from Canada?
Old 03-07-11, 07:03 PM
To clarify: pcboss - the white is neutral and goes to the lights not the switch loops like a 3 way. I'm from Jersey not Canada.
Thanks guys!
Old 03-07-11, 07:57 PM
I am not familiar with NMW I thought this was the equivalent to NM-b in Canada, which is why I mentioned it. Could you please let me know what it is? (I googled NMW and got NMWU, If this is what your using I think your making more work for yourself.)
Old 03-08-11, 06:26 PM
I meant NM-B - sorry. I think that was a mashup of everything in my head. Or, it could be the fact that everyone in Jersey has an attitude always...
