Need to install more plugs
Old 03-08-11, 12:51 PM
dianemurphy's Avatar
I need to install more plugs in my walk in closet. I have an electrical baseboard heater which I don't need. Can I remove the heater and replace it with an electric outlet instead?
Old 03-08-11, 01:49 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Probably. What is the voltage and breaker size? Are there any other heaters on the same circuit?
Old 03-08-11, 05:50 PM
Received 32 Votes on 24 Posts
I'm going to counter what Ray wrote and say maybe. If this no longer needed heater is on the same circuit as other heaters then most likely you will NOT be able to use the same wiring. Does this heater have a self-contained thermostat or is the thermostat on the wall?
