Reload this Page >
Switch not operating outlet anymore! The brass tab IS broken. Help!?
Old 03-13-11, 05:26 PM
Question Switch not operating outlet anymore! The brass tab IS broken. Help!?
I changed out an outlet because it was old and not holding plugs well anymore. One of the receptacles was on a switch but now both receptacles are always hot. I DID break the brass tab on the hot side but that didn't change anything. I've also changed the switch out but still both outlet receptacles are hot.
Within the outlet box is a black hot wire, an orange hot wire (goes back to the switch), & a white neutral.
The switch box has a black hot & orange hot wire
Please help!
Old 03-15-11, 03:46 PM
It sounds like you didn't connect the wires back the same way. How it should be wired depends on where the power is coming into, whether it's into the switch box or the receptacle. See the below diagram:
Grounds aren't included for clarity. Also, the wire from the receptacle to the switch probably has a Black, Red and White wires. The white wire may be capped/cut, or may be in use.
