Breaker size for 15 amp single phase
Old 03-14-11, 08:42 PM
I have a new air compressor with a 3.5 HP single phase motor that says 15 amps on the motor sticker. I ran 10-3 wire from my panel to a disconnect box and the wire run was 55 feet. I installed a 20 amp double pole breaker in the panel. Will that be a big enough breaker to keep it from tripping on start up?
Old 03-14-11, 08:54 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
It should be large enough. No need for 3 conductor cable on a 240 line.
Old 03-14-11, 08:59 PM
Thanks for the reply. I didn't know for sure on the wire so I figured it was better to have a little bigger and 3 conductor wire. Electrical confuses me but I'm learning.
Old 03-18-11, 05:51 PM
Got it hooked up and works great!
Old 03-18-11, 07:02 PM
ray2047's Avatar
Good job. Thanks for letting us know.
