Junction box question
Old 03-24-11, 12:02 PM
Hi everyone,
So, im mapping out a whole room rewire and I had a question about junction boxes. If I were to run the main line (12/2) from the service panel to the room I'm rewiring then split it in a junction box before I start going to any outlets or switches can I still utilize AFCI breaker protection for both of the lines after the split?
The junction box would have two branches, and each would be utilized in the same room. I was thinking of using the jbox to reduce the drywall, stud, and joist drilling.
This is a bedroom so I wanted to use the AFCI breaker.
Old 03-24-11, 12:27 PM
As long as it is only one 12/2 (hot, neutral, ground) cable leaving the main panel for this circuit, the AFCI breaker will function correctly.
Old 03-24-11, 12:30 PM
Thanks,
Yes, it is one 12/2 line going from the service panel, to the junction box, where it splits to two branches. Both branches will be used in the same room. And an AFCI breaker of course.
Old 03-24-11, 01:45 PM
Justin Smith's Avatar
The box must also remain accessible.
