plumbing pipes near receptacles?
Old 03-29-11, 10:44 AM
hi folks –
I have an unfinished basement and I have an GFCI electrical outlet in a box fastened to the masonry block wall. The wires come down into the box through EMT from above at a joist. I need to move some of my plumbing pipes (3/4 inch).
I was wondering what are the rules for plumbing piping and other obstacles near a receptacle box? I guess obviously you couldn’t have anything right in front of the box blocking the receptacles. But, for example, would it be OK if you had a 3/4 inch water pipe riser, say a few inches left or right of the box ? Or is there some minimum distance you must keep away from receptacles?
Any help would be greatly appreciated!
Old 03-29-11, 11:12 AM
No minimum distance requirement.
Old 03-29-11, 05:53 PM
Gotch Furd!
That's an easy answer to understand.
Thanks again!
Old 03-29-11, 06:00 PM
You're welcome!
I like the easy questions.
